What fuse ? Regular mini fuse ? Just pull it out with the fuse puller tool located in the fuse box compartment . Replace with same number fuse . 5,10 , 20 , 25 etc.. what ever it is . How To Safely Change Blown Fuse
? 6:25
https://www.youtube.com/watch?v=xwJodTmj7Jo
Apr 8, 2009 - Uploaded by bountyCXVII
Just a simple video about how to check, and replace possibly burn out fuses. also it shows where both fuse ...
? 3:32
https://www.youtube.com/watch?v=faWZmG0fXy8
Jul 1, 2011 - Uploaded by 1A Auto Parts
How to Find and Replace A Blown Fuse in Your Car or Truck ...How To Wire A Fuse Block - Easy - Duration: 10:56. klowny1969 9,283 views.
CarGurusMar 3, 2013 - That's where you will find your rear fuse block. ... The fuse panel is accessible by removing the shroud cover. ... 2001 Cadillac DeVille Base.
www.dummies.com/how-to/.../how-to-change-a-vehicles-fuses.html A fuse box located under the hood. ... A fuse box is easy to recognize, and replacing burned-out fuses is a fairly simple matter. ... Before you open or work on a fuse box, be sure that your vehicle's ignition is turned off.
www.dmv.org/how-to-guides/fuse.php The Unofficial Guide to the DMVDon't stress out, it's a pretty easy procedure. ... Step-by-Step: How to Change a Fuse... Replace the blown fuse with a new fuse of the same amperage. ... Consider using the fuse for your cigarette lighter, the radio, or the back window heater.
Fusing Pressure Roller warm-up failure
• The voltage of the Fusing Pressure Roller Thermistor does not increase by five steps within 20 sec. after the predrive of the Fusing Roller has been started during a warm-up cycle.
Remedy
1 Check the Fusing Unit for correct installation (whether it is secured in position). 2 Check the Fusing Unit, PWB-MC and PU1 for proper connection and correct or change as necessary. 3 Change Fusing Unit. 4 Change PWB-MC. 5 Change PU1.
Step 2 Check: Fusing Heater Lamp (H1) is open-circuited. <Check Procedure> Check the resistance across both ends of the Fusing Heater Lamp (H1). The Fusing Heater Lamp is open-circuited if the resistance is infinity.
Step 3 Check: Thermoswitch 1 (TS1) is operational. <Check Procedure> Check the resistance across both ends of the Thermoswitch 1 (TS1). The Thermoswitch 1 is open-circuited if the resistance is infinity.
Result: NO Action: Change Thermoswitch 1 (TS1).
Step 4 Check: Fusing Unit Interlock Switch (S2) is operational. <Check Procedure> Check continuity across terminals when the Fusing Unit Interlock Switch (S2) is turned ON. • Across S2-1A and S2-1B • Across S2-2A and S2-2B
Result: NO Action: Change Fusing Unit Interlock Switch (S2).
Result : YES Action: Change DC Power Supply (PU1).
Step 5 Check: Thermistor (TH1) is open-circuited. <Check Procedure> Check the resistance across CN15-2 and CN15-3 on the Fusing Unit side with CN15 disconnected. The Thermistor is open-circuited if the resistance is infinity.
Result: YES Action: Change Thermistor (TH1).
Step 6 Check: The following voltages are supplied from the Master Board (copier: PWBA). <Check Procedure> Check voltage across a Master Board (copier: PWB-A) pin and GND when the Power Switch is turned ON. • Voltage across PJ10A-7 and GND DC24 V when Fusing Heater Lamp (H1) is OFF DC0 V when Fusing Heater Lamp (H1) is ON • Voltage across PJ10A-10 and GND DC24 V when Fusing Heater Lamp (H1) is OFF DC0 V when Fusing Heater Lamp (H1) is ON
Result: NO Action: Change Master Board (copier: PWB-A).
Fusing abnormally high temperature detection (heating side) Check the fusing unit for correct installation Check the fusing unit, PRCB and DCPU for proper connection and correct or change as necessary. Change fusing unit Change PRCB Change DCPU
