Hoover Nextra 160 HNWF 3137 Front Load Washer / Dryer Logo
Posted on Nov 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hoover nextra wont fill
My machine stopped working there is water going to machine but it wont fill the drum still works just no water i checked for blockages everything fine
  • Anonymous Jan 19, 2008
    same problem as above.
DENNIS MITCHELL
Level 3:
Genius:
  • Master 1,003 Answers
  • Posted on Feb 02, 2008
DENNIS MITCHELL
Master
Level 3:
Genius:
Answers
1003
Questions
0
Helped
367195
Points
2185
REPLACE WATER INLET SOLENOID
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Hoover Nextra No Lights Not working
please check the fuse in the plug it should be13 amp it has no doubt blown after replacing it and happens again there might be a problem with the heating element it might be faulty or ruptured due to short circuit in the element eric
HI We have a Hoover 700LD washing machine that wont fill or wash. Will drain and spin. Any ideas? thanks
Thanks for choosing FixYa and welcome. You need to check your water inlet valve and make sure it is not defective. Check your water pump and make sure it is working right. The pump pumps the water into the washer.
2helpful
User manual for hoover nextra tumble dryer
I have a Hoover Nextra washer/dryer machine. It has been working fine but 2 days ago it stopped taking water into the drum. When I put the machine on, I can hear water running into it and the water does go into the powder compartment and clears that. However, only a tiny bit of water is getting into the drum of the machine.
In case it is relevant, there is only one hose at the back, not 2 hoses like some machines have. I don't think it can be water pressure as it has always worked before.
I hope someone can maybe give an idea as to how to fix it as I have toddlers and need it fixed asap. Is there anyway we could fix it rather than have to call out a service engineer. If there is something we can try can you answer in simple language as we don't know much about washing machines.
Thanks very much
Dec 21, 2010 • Dryers
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
1helpful
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
4helpful
2answers
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
