Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFHS2611LWF, is flashing an "H1" code. This is actually stating "HI", as in either the refrigerator or freezer, temperatures are Hi and not at a safe level. First, press any button to stop the alarm and clear the HI temperature. If you are still receiving the alarm, I suggest checking the freezer, to make sure that everything is still frozen, and nothing is defrosting as, well as checking the refrigerator temperatures. If things are defrosting or the temperature is Hi in your refrigerator, I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, Give your freezer 24 hours to stabilize at the default temperatures of 0 degrees for the freezer and 37 degrees for the refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully.
-Best Regards-
WP
I have the same problem, & it's been days since I plugged this fridge in to use it & neither side is cooling hardly AT ALL, & the compressor kicks on for maybe 10 seconds then kicks off & won't kick on again for like 20+ minutes....HELP. Thanks in advance!!!
I have the same problem but lastnight the outlet had some sparks coming out of it that stopped but now the beeping wont stop and I've tried unplugging the refrigerator as well as the temp
Mine was flashing h too everything checked out fine it's bc we have air cond on the setting 6 was too high and it froze the back coil.we turned down the freezer and it's fine now. Hope this helps someone else oh the stress for nothing.lol
Tried all these and none worked. However, found the crossover (the part that allows cold air from freezer to crossover to fridge) in the fridge was frozen. Removed ice and felt airflow moving. Also seen where I might have a small leak in the icemaker causing excess moisture.
I too have the 2611phea and had a flashing H then 1. I touched the temp button and the freezer reset to 8.... I didn't notice any issues. The problem is do have is that the ice maker is not making ice... is it relatedoesn't? Water dispenser flow seems normal and we hear a buzzing sound every few minutes assuming it's in the ice maker...but no ice. THOUGHTS?
I had the same problem with a different model and the fridge reset upon using the a button. Just curious, what could have caused this to happen and should I be concerned that it will happen again? Many thanks
