I have tried the solution regedit, which didn't help... There is also no num lock buttom on the keyboard.
Press FN+Shift+Num Lk key at the same time
Here are FN + F key combi for your reference.
Press Fn + F9 keys for Touchpad Lock (on/off).
Function Keys:
Fn+F1 Suspend switch
Fn+F2 WLAN switch
Fn+F2 Bluetooth switch
Fn+F3 Access to the E-mail
Fn+F4 Access to the Internet
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Space Power 4Gear eXtreme
Fn+C Splendid
Fn+T Power4Phone
Fn+V Camera capture
Fn+A Light Sensor
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders. Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values. hope this helps
or
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
