If you insert the SD card into your TomTom device, and you can see it ... as one of the maps on your device ( when you go to Menu ... Change Map ... etc. ). ... try selecting that map, and if it doesn't tell you it is not available or not activated, then you can use it. Otherwise, you need an activation code to activate the map.
If the map on the SD card is a LifeTime map, you can simply connect your device to the tomtom website (using the HOME software), and it will let you know you have an update (of that map) to download and install. Otherwise, you have to subscribe (i.e. pay) for an update of the map.
SOURCE: tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
