SOURCE: Whirlpool Cabrio
that is a suds detection error code try not using so much detergent then see what happens
SOURCE: Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
SOURCE: washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
SOURCE: whirlpool cabrio is giving a code which is f1,
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies,
and visually check that the P11 connector is inserted all the way into
the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has
failed: Unplug washer or disconnect power. Replace the machine/motor
control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
and visually check that the P5 connector is inserted all the way into
the machine/motor control. If visual check passes, replace the user
interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or
disconnect power. Replace the machine/motor control assembly. Plug in
Some buttons do not light indicators:
and visually check that the console electronics and housing assembly is
properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
