no shop manual> working blind?
real name
Harley-Davidson FXDL Dyna Low Rider 1993?
well the handle bar kill switch tripped (dead/man switch)_
all fuses good.
the 2 tower coil means this engine fires in wasted spark mode.
2 at once simple , cy1. TCD compr. and cy1, TDC, exh stroke.
and will file if either spark plug is unplugged or plug is dead.
the 2 HV spark wires if either are open both fails. dead.
that is how wasted spark works, (google and learn)
use new HV wires and 2 new plugs. if this end fails.
next, above not wrong
we test the primary side of the coil for signals proper.
12dc to coil + primary pin
the coil - primary goes to the.computer control module
the CPU will not generate spark if the crank sensor is dead
the breaker plate device. now called the sensor plate.
in car jargon the crank sensor, ckp is dead.
see this drawing, WS, see how wasted spark looks
sparks 6a and 6b are wired inseries , if one fails open both fail.
the + lug must have 12vdc keyon for fix that first (fused)
key + fuse
majic jack problem. Not android tool apps..
