It was opened initially by some experts trying to fix the sound, then after that it started to do this.
SOURCE: No service on my unlocked Motorola RAZR V3
fool with the small copper antenna located next to the battery it worked for me, i had the same problem. Try moving the antenna around with a small screwdriver
SOURCE: my razr v3 phone browser
Sounds like you may need to update your configuration settings. If you are not using an unlocked phone a master reset should do it. If this doesnt work call your carrier they should be able to update your browser settings
SOURCE: Motorola razr v3 display went out
Either your flex cable is broken or came loose. Is the top left hinge button still intact? Is it loose at the hinge? You will need a Torx 4 screwdriver to take the LCD screen apart to check the flex cable inside.
SOURCE: motorola razr v3 not catching signal
you will need to get a new motherboard put in the phone( contact your service provider)
