Question about Dell OptiPlex Computers & Internet
755 pxe-e55 proxyDHCP service did not reply to request
ON boot from network says 755 pxe-e55 proxyDHCP service did not reply to request from port
    Genius:
  • Dell Master
  • 1,552 Answers
PXE == Pre Execution Environment
Your computer can "boot" from various devices:
* floppy-disk
* CD-ROM
* USB memory stick
* DVD drive
* hard-drive
* over the network
If you don't have a "network boot server" somewhere on your network, you will get that "boot failed" message.
Enter BIOS SETUP mode, and disable "PXE boot over network", and make sure that the hard-drive and/or the CD/DVD drives are listed as candidates to be eligible boot-devices.
Posted on Oct 24, 2014
Anonymous
SOURCE:
Black screen with white letters reading "REBOOT AND SELECT PROPER BOOT DEVICE"
Misty here is what I would do:
1.Start the computer in safe mode.
2. update drivers. I go into Slim Driver - a free prog. and scan the system to see if ok or need updates.
3. once updated, reboot the system normally - any change? GL
Feb 01, 2014 | Dell Inspiron M5030 Laptop
The screen says: "Intel UNDI , PXE-2.1 (buld 082) For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080225) CLIENT MAC ADDR: 00 03 0D A0 C7 C7 GUID:...
Your computer tries to "boot" from various devices:
* internal disk-drive
* internal CD/DVD drive
* internal 3.5" drive
* external USB device (memory stick, external CD drive, et cetera)
* via your network-adapter -- trying to connect to a "boot-server"
So, restart your computer, and enter BIOS SETUP mode.
Be sure that the disk-drive *IS* listed.
If you want, exclude the "network" boot-device,
since the error-messages that you are seeing are indicating that *NO* boot-server exists on your network.
What the messages *COULD* imply is that there is no media in the CD/DVD drive,
no media in the 3.5" drive, nothing "bootable" connected via a USB port,
*AND* that your computer *TRIED* but *FAILED* to boot from your disk-drive.
That is, your disk-drive either is electrically disconnected (no power reaching it)
or electronically disconnected (the "data" cable is not attached)
or that the disk-drive itself is "dead".
Take your computer to a qualified technician for trouble-shooting.
You may have to replace the "dead" disk-drive with a brand-new one.
Oct 10, 2010 | Computers & Internet
When i start the laptop it shows media test failure,check cable exiting pxe rom os not found
Your computer is configured to try to "boot" from several devices:
* floppy-disk
* CD/DVD drive
* disk-drive
* network (via connecting to a "boot-server" on your local network)
So, "media test failure" means that no Ethernet cable is connected to the network-port on the computer. So, if you are trying to boot from a "boot-server" over the network, check that the Ethernet cable is connected, and check that the boot-server is processing boot-requests.
Thus, the PXE (Pre eXecution Environment) is exiting, because it cannot boot from the network -- no Operating System was accessible over the network.
So, enter BIOS SETUP, and disable the "network boot" option,
if no boot-server exists.
Also, put a boot-disk into the floppy-drive, or the CD/DVD drive,
or, most importantly, check that your disk-drive is working.
If your disk-drive is not getting power, or its "data" cable is not connected, or if the disk-drive has a problem, then Windows cannot be read from the disk, and so the computer tries an "alternate" boot-device.
Sep 03, 2010 | Computers & Internet
My computer fell and when I turned it back on it's saying check cable connection..! PXE-E63: Error while initializing the NIC pxe-m0f:Exiting Intel pxe rom no bootable device
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
Nov 09, 2009 | Acer Aspire One PC Notebook
Keeps saying pxe e61 media test failure on boot
Your PC is trying to boot from your ethernet port(internet). It is trying to see if it can boot to that before it boots to your Hard Drive. It is normally used in businesses that have PC's that boot from a Server on the Network. Home users don't usually use PXE.
To change this go into your BIOS.(F2, or F12, or DELETE, or some key when you first turn the PC on) And you should see something called boot order, change the order to boot from the Hard Drive FIRST, CD Drive SECOND, and PXE THIRD.
Or you could turn the PXE off, you should find something in your BIOS like "Onboard Devices" and it should show "Ethernet" or "Network" as an option with choices like "ON w/ PXE", "ON", and "OFF". Change it to just "ON". And you should be fine. If you turn it "OFF" then you won't be able to use the ethernet(internet) port at all. Just set it to "ON".
Not a big deal, if it can't boot from the Network it will go to the next bootable device, which is probably your Hard Drive. It won't hurt you or your PC; it just takes an extra few seconds for it to boot to Windows instead of the Network.
Sep 30, 2009 | Acer Aspire 5315 Notebook
Argon PXE Boot Agent v2.01 2002 - PXE - E61
Your computer tries to "boot" from several devices:
* floppy-disk
* disk-drive
* CD-ROM
* USB memory-stick
* over a network, via PXE (Pre eXecution Environment)
If you have a network-cable connected to the Ethernet port on the computer, with the other end connected to a "boot-server", then the Operating System can be loaded over this network-connection.
But, if you get "media test failure" and "check cable", then the network-cable for PXE is either non-working or not-present.
Any disk-drive that shows "ZERO" blocks is very probably a DEAD disk-drive. Replace it.
Jun 03, 2009 | Compaq Presario 2100 Series: 1170B01-90...
PXE-E61
Your disk-drive has failed.
So, your computer tried to boot itself over the Ethernet network,
by "broadcasting" a request for booting. When either the network-cable was _NOT_ connected, or when _NO_ computer responded to the "broadcast" message, you get "PXE: media failure".
Take your computer to a qualified technician,
to remove the "dead" disk-drive,
to replace the disk-drive,
and to reinstall Windows.
May 26, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Acer Aspire 3000 problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} No. JUST RESET YOUR BIOS SETTING TO DEFAULT. Your HD is OK
Sep 11, 2008 | Acer Aspire 3000 Notebook
Having trouble with boot up
It was unfortunate that the chat got disconnected deu to some unknown reason. I was able to find some solutions for you, however, to follow all those steps I would need to talk to you continuously. Whenever you see me online, please initiate a chat with me and we will carry on from there. good luck
Mar 26, 2007 | Acer Aspire 3000 Notebook
Open Questions:
Dell Printer@^+[1]=855-221-4867@&@tech Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
131 people viewed this question
Ekse
Thomas F. Schneider
Shawn DuRee
