Was using internet connection from desk computer to HP Chromebook, however it got disconnected and I don't remeber password. How do I recover password.
The Chromebook has a wireless network interface.
So, it does not connect to your computer.
Instead, it connects to your wireless router.
If you do not remember that password for your wireless network,
you need to "reset" your router to its "factory-settings", and then recreate the name of your wireless network, and enter a new password, to define it.
SOURCE: cannot connect to internet thru ethernet jack on computer
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
SOURCE: HAD INTERNET CONNECTION...NOW GONE
try shutting down your router for about 30 seconds, then power it back up, you should be able to get your connection back..
