A
Anonymous Posted on May 19, 2014
What does Error 630 mean forr MITA DC 3060? - Kyocera Mita Office Equipment & Supplies
4 Related Answers
Anonymous
  • Posted on Jan 20, 2009
SOURCE: Mita error code
in mita DC.1856 what is solve the problem ,that code error is (C45)
Anonymous
  • 389 Answers
  • Posted on Oct 08, 2009
SOURCE: Dear sir, i have one
C630 Open fuser thermistor
Anonymous
  • 622 Answers
  • Posted on Dec 24, 2009
SOURCE: ERROR CODE 630 KM1810
replace the fuser...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Anonymous
  • 3085 Answers
  • Posted on Apr 17, 2010
SOURCE: Mita DC-3060 When i try to print display the
You need to have your developer changed.
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
M559200308
It is not a colour copier and uses toner cartridge.
2answers
I change the toner in kyocera FS-1135MFP but still it is asking to change the toner why ?
clean the developer and add toner powder to it then try to print without putting a toner if fine then install the toner problem solved
How to add developer on a mita DC-3060 copier
This needs to be done by a technician as you can easily damage the drum!
1helpful
2answers
System error cfb 30 kyocera 3060
CFB30 :
Incompatible Level Of Firmware on Main EEPROM.
My copier mita dc 3060 showing error code c 210
Hello Manuel sorry for your machine to be in that stake but have you tried to check on that paper conveying motors because that error is for those lift motors try to go on your machine run this code
press status/job cancel
enter 1087*2 twice
enter 906 and then you will see execute
the you press start to see whether it will stablize
2answers
this code means the fuser unit error.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
2helpful
4answers
Mita error code
I think that stands for OPEN. Check to make sure that all the doors are closed. Right side, left side door, and also front door.
Hope this helps.
If you still have the OP message, then let me know and I will dig out my books and look it up.
Good luck.
Mac
2helpful
Error C63
That is the same as a Kyocera Mita DC 1470.
Error C63 is a fuser related error:
Broken fixing unit thermistor wire
• The fixing unit thermistor output voltage does not exceed 0.039 V DC within 7 s after fixing control has started with the fixing temperature remaining below 100°C/212°F (fixing unit thermistor output voltage: 1.71 V DC).
I can provide for you a full service and parts manual from Mita in PDF form for a nominal fee. Contact me for more info here.
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
