I have tried clearing the spooler queue and restarting print spooler service. I can't get past this error and Brother says it's not their problem
I had this problem when tried to install network driver to Brother HL-L2340D (exactly InstallNetworkDriver - 3, not InstallNetworkDriver - 1). Tried it several timers, when print spooler service was running. But still got the same error.
Finally, i forgot about install wizard and installed driver manually (for my Win2008R2x64, it was DeviceManager >> Install old device >> Manual choice from list >> Show all devices >> Install from disc >> target to unzipped wizard content folder (...install/driver/gdi/32_64) >> select wanted printer model in appeared list >> continue install it.
After that, you can install this printer with standart applets of control panel (Printers > Install printer), it successfully finds printer in network and add it to list.
So, i still don`t know the reason, but have the solution.
SOURCE: IS034 Error when intalling driver software for MFC-490CW on vista
This issue is cause when the print spooler service isn't running, MFL pro installs the printer driver 1st (after paperport install) which will not wun if the service is disabled
SOURCE: Won't print to network printer
do you print it to the computer were the printer were you want to print or to another computer were the printer is installed to other computer and you trying to print it by search it to the network to print..if it is the same OS that you are using there is no problem on it..but if it is different OS like you likr to print it to the pc if it is win 7 but the printer is connected to a pc were win xp is the OS he/she using you must install it again..go to youtube and search..how to print to other pc by network.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\
folder. You should see files there ending in .SPL and .SHD created around the
time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the
Try to print a document again to verify that the problem is fixed.
1. Browse to Start -> Run... and type in "NET STOP
SPOOLER" (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder
3. You should see files there ending in .SPL and .SHD created
around the time you tried to print - delete these files.
4. Browse to Start -> Run... and type in "NET START
SPOOLER" (this will restart the print spooler service)
5. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
