SOURCE: 37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
SOURCE: the power light on my sharp aquos blinks green and
TV detected lamp error, problem could be either INVERTER UNIT or one of the lamps. Defective part has to be replaced, lamp error counter reset.
SOURCE: incompatible video signal has been recieved
I just had the same problem and it turned out to be the HDMI cable.
SOURCE: Freeview channels (DTV) on a Sharp Aquos TV
On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
can anyone help
