My guess is the printed circuit control panel(the brain) is going south.
There is nothing you can do with these normally, best to get a domestic appliance guy/gal to check it out. If you want to search the web for a replacement get to the back of the machine, write down the make/model/serial number/ anything else, off the manufacturers plate.
You will need this to determine any spares are correct. Don't work on the basis that a similar machine or even the same model will have the same part because appliance manf are notorious for changing specs during production.
You may find that another brand is listed as well as your own, this is because they have the same factory but are badged according to brand or region.
If the machine is old and had a good beating then you may find it more economical to buy a new one. The brain can be 50% of a new buy!!
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
SOURCE: Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
SOURCE: water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
SOURCE: Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
