TeSoar Tablet Stuck on TeSoar logo screen when it starts up
When I turn it on, it does and works properly until it gets to the tesoar logo (which is in blue with a white background)it stops and sits there for a long period and its only suppose to sit there from 30 seconds to a minute. Could someone please help me with this problem.
This is not the Velocity Micro Cruz Reader R101 Tablet pc. I have no idea why it says it is that but this is the 4gb tesoar tablet.This is not the Velocity Micro Cruz Reader R101 Tablet pc. I have no idea why it says it is that but this is the 4gb tesoar tablet.
You can't post conmments that contain an email address.
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the volume + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
If that doesnt work then go into recovery mode usually by pressing the power button and volume up buttons at the same time then selecting restore tablet option.
If you tablet is corrupt you will have to sideload or reinstall the os from a usb stick.
If a factory reset to default won't work, which it looks like it won't, I think one course of action is to open the back, disconnect the LI-ON battery, (it probably has a small, delicate three pin micro plug, so care is the operative word!), wait about 10 seconds or so, then reconnect it, and see if it then powers up properly.
That is what I did with my T310 when it went into a state of limbo.
Word of caution, opening the back will more than likely invalidate any warranty you have.
