Cell Phones Logo
h
harold niedzielski Posted on May 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Call divert set message when making calls
When making calls a messages appears saying call divert activated
Sanjiv Sharma
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 139 Answers
  • Posted on May 21, 2014
Sanjiv Sharma
Expert
Level 2:
Filmmaker:
Answers
139
Questions
0
Helped
398538
Points
241
Thats a network service provider setting....from settings...select CANCEL ALL DIVERTS.......if this does not work contact your network service provider
I can make calls, text, but all my incomming calls go straight to voicemail. What's the problem?
Denise,if the phone is a nokia, go to tools in main menu then"settings" and open. scroll to "call divert" and open. you will be in "call divert settings", open "voice calls" and "cancel All Diverts" . then reopen "voice calls" and scroll to "if out of reach" push "options" and "activate".. your diverts will then only come through when the phone is out of area or turned off . you will then get a message when your phone is on again or back in area. other phones are similar and you will need to find similar settings, regards Terry
1helpful
2answers
I want to dirvert calls to another handset plerase help
go to the call settings then click on the call divert option then click divert all voice calls then on that select the option as divert to another number then feed the number inside the tab now click ok check the status now if it says activate then its ok. If not activated then contact your service provider to activate the call divert for your number . because they may block divert optoin for your number
Jun 15, 2011 • Cell Phones
Getting this message .call divert set. what is it and how do i get rid of ot ???
When you make a call it will say this As while your in a call it will need to divert calls to voicemail as you cannot answer two calls at once..
Don't worry about this, If its Set for always diverting then In settings > Call or network settings you can disable all diverts.
If its just appearing when making a call then ignore it, Its perfectly normal.
4helpful
2answers
My nokia 3110c shows a message like active incoming call diverts when ever i dial a number what does it mean?
It means that you have set up that incoming calls will be diverted (to your voicemail usually) when your "line is engaged", ie when you talk with someone on the phone.
There are 3 diverts: divert on busy, on not available (switched off or out of range) and on no answer (when you don't answer after a certain period).
Depending on operator, they can be activated or deactivated individually, or all three at the same time. The latter option is bad in my opinion - who needs divert on busy? If the phone is busy, try again in a couple of minutes I say...
Anyway, this message is nothing to worry about.
4helpful
My n95 keeps making an engaged tone and saying 'diverts active'? how do i stop it?
Its showing Active diverts because your call diverts is active. May be you have set a call diverts where if you are unreachable your calls gets transfered to voice mail. To deactivate Active diverts. Go to Tools -> Settings -> Call Diverts -> Options -> Cancel all diverts
Hope this helps.
Motorola em326g call divert won't go off
hi
what you ahve activated is calling divert it is a simple thing to turn off but handy when you need to divert a call somewhere , you go into the settings menu of your phone , then calling , then call divert press this and then it should say activate , deactivate, or staus press staus to make sure for definate that it is on and then press deactivate then you should get a confermation message appear and its done
When calling in my phone always says your call has been forwarded to an automated messaging system
If you can make calls OK, then it's possible that you have the phone set to divert all calls - you can check this with
*#21#<send>
If it comes back with some message like "Divert active" or "Divert all calls: ON", then clear it using
##21#<send>
2answers
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
2helpful
PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Voicemail only picks up if my phone is turned off other wise i get a missed call message. I canot be paged and message cannot be left phone must be turned off.
this will happen if u have activated the call divert option ...
just go to call settings in that call divert options give "cancel all"
then this will cancel....
u must have activated the "call divert""if not reachable or switch off"... cancel it first...
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
