Question about Kyocera FS-1028MFP
What is error code CF248 mean
Why is the screen in lock mode on error cf248,it will not allow me to exit the screen or clear any thing out or even go into settings Kyocera 1028mfp
  • Morne Aug 27, 2015
    Hi, cf 248 sounds like a driver issue.
    If I remember correctly I used a different driver and it solved mine.
    Hope this is helpful
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
Try formatting the hdd
Posted on Aug 07, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: Service call error
How do. replace the Rt. bush for the transfer roller have part but
having trouble removing and replacing it?
Chris
Posted on Feb 25, 2008
mochicas
  • 26 Answers
SOURCE: error code C0F37 on Kyocera mita KM-C1530
This code is not documented, the firmware must be reloaded and a service tech can only do it ...
Posted on Feb 21, 2009
Copier_God
Brian
  • 57 Answers
SOURCE: I need to know what error code A400 means?
The polygon motor in the laser unit is faulty, you must replace the laser unit.
Posted on Oct 16, 2009
shawn38
Shawn
  • 200 Answers
SOURCE: Kyocera FS-1028MFP has been set
You may contact Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482, they should be able to assist you with this and there is no charge for the call or thier help.....totally free.
Posted on Jan 18, 2011
Tam Software
SOURCE: When i scan to email,
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Posted on Sep 12, 2011
How can I clear locking mechanism?
Only fix is to enter service mode and when you exit it should remove the stored code and allow you to restart unit. If not and you are certified you can call the Tech Line for more assistance. 1-800-662-3587. They will ask you for there account number before helping you. First enter service mode, allow auto test as it will test door locks, fill, drain, and spin functions. When you exit after this test it should allow you to restart the unit as normal. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 08, 2016 | Maytag MAH21PDD Commercial Front-Load...
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 28, 2014 | Office Equipment & Supplies
I am recieving machine failure on kyocera 4200 dn
The most common machine failure codes is CF---. For example CF248, CF000. In the most cases the printer is need to be upgraded to the latest firmware.
Jun 10, 2014 | Kyocera FS Office Equipment & Supplies
How do i set driver back to kpdl
from experience when ever I get a problem like this I generally delete the relevant driver and then reinstall it. check that the driver is compatible with your operating system. This is all I can suggest as it takes very little to corrupt a driver.
May 20, 2014 | Kyocera FS-1118MFP Laser Printer
Error power f24b
Are you sure about the CF24B? A much more common error is CF248, which is a print data error. Just clearing the corrupt print job will resolve this error. From what I've seen, some crucial packet of your print job got lost, and never made it to the printer. If it happens often, I'd look for a corrupt or wrong print driver.
Sep 19, 2013 | Kyocera FSC5150DN Laser Printer
Kyocera FS 1128mfp error code CF248 - what does this mean?
corrupt print data.
set the driver back to KPDL, make sure to uncheck the "allow data pass through" in the settings area, this makes a world of difference and ends up eliminating alot of print errors. It's been talked about in other threads on this site. I've talked to KM tech support about this setting and they don't really know what it is for
Mar 14, 2013 | Kyocera FS-1118MFP Laser Printer
Replaced broken motor coupler and motor still saying problem has been detected with drive system
With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed.
Dec 01, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
Kyocera FS-1028MFP Logo
390 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
