I just replaced the drain pump and added the enclosed fuse and fuse holder. The washer was put back together and now the washer will not power up. There is power at the outlet. I have a Fisher and Paykel IWL16.
SOURCE: washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
SOURCE: fisher and paykel washer doesnt turn on. no power
There are solder in slow burn fuses located on the circuit board that can burn out if the pump gets clogged or broken and some other reasons that you can buy from Mouser electronics using p/n (mouser) 576-37416300410 or Mfg p/n 37416300410. The fuses are reddish, round cylinders about .5 inch high and wide. Anyone who can solder can easily fix this. Be sure to tag any connections that you remove although all you need to do to get the circuit board out to work on it is remove the small rubber hose and 2 electrical plugs connected to the board through the outside cover. There is paperwork inside the head of the machine (and there is the circuit board) with fault codes to help you determine what your specific problem could be but I had a no power problem recently and replacement of these 2 fuses fixed it. Let me know if you need further help!
