Blutooth is a low powered radio system by which data is transferred between devices such as cell phones and wireless headsets, cell phones and computers to get photos and music, stereo headphones and audio systems.
TURN ON UR BLUTOOTH OF UR DEVICE THROUGH WHICH YOU WANT TO PAIR....... HOLD THE KEY OF UR BLUTOOTH HEADSET..... THEN AFTER YOU WILL GOT A MSG IN UR DEVICE AS"add a new Handsfree(WHATEVR UR HEADSET NAME IS) device" THEN SELECT YESS...... then it ask for passkey ....enter "0000" or "1111" or "1234" these are the normal passkey......or otherwise ask ur blutooth headset company for passkey..... hope this will help u.....enjoy it
yes. you must first register the device with your computer through the bluetooth manager. once they are linked you can transfer the install cab file by blutooth, but you must actually install the file from your device. please rate me if this helps. thanks and good luck!
Uninstall the LAN drivers and restart the system.. Install the drivers again and check specially for Brodcomm Drivers in Device Manager.. Restart the system and make sure you plugin the Blutooth Device with your system... It should be working....
hold the bluetooth on button while the phone is in pairing mode this is how it finds it and if it asks for a pin at the end
ok this is simple they dont put it in the books but i found out going to the techs.
when it gets to the pin type in 0000
1234 or 12345
i dont know why they dont put these in
first put the blutooth in pairing mode...what model of bluetooth is it i might be able to tell you hwo to do that if you dont knwo how. than turn cell phone on if not already.click the main menu button and then the settign folder. scroll down to connection and click itthen click "blutooth link"then go down to "add audio device" click yes to turn on bluetooth then if blutooth is correctly in pairing mode it will find it when it does click on it and piut in the pass word 00000000. and your done.
You just have to press your blutooth on/off button a bit longer for 15 to 20 sec, when the LED blinking stops (noted that the LED should be turn ON but not blinking), try to search the device again with your phone. By that time your blutooth headset should be recognized by your phone, then select and enter the code 0000.
