Microsoft Surface RT Logo
J
Jesus Sepulveda Posted on May 21, 2014
How to you switch a crack digitiser screen to new one on a surface rt?
My Surface Rt front screen craked only the glass and need to know the instruction in how to be able to switch it for a new one that I could do myself?
Is it possible to transfer pictures from a memory card to the surface rt tablet
Use either microSD card (Surface has a slot for this card), or SD card with USB adapter. This way it is easy to transfer pictures .
How do I shut down my Surface RT
if you do not mind loosing any data press and hold reset button for 30 seconds will set back to factory default settings or snap case open and try cleaning button surface where it connects
How do i get my RT to boot
Here are the steps to go back I factory setup. It will remove everything personal you have on the Surface - photos, docs, etc. They will still be in the Share drive if you utilized it for storage.
  1. Restart the device made for Surface.
  2. Press F8 during the initial BIOS post to bring up the Advanced Boot Options screen.
  3. On the Advanced boot options screen, use the arrow keys to highlight Repair your computer, and then press Enter.
  4. Select a keyboard layout, and then click Next.
  5. Type the user name and password of an administrator, and then click OK.
  6. Under System Recovery Options, select Reinstall Windows. This option will restore Surface to the factory image, and any customized user information will be lost.
  7. When the restoration of the factory image is complete, the device made for Surface will restart, and the setup process will begin. This process is identical to the first time you set up Surface; you will be guided by a series of prompts and dialog boxes.
One more note - if you deleted the restore folder to save drive space this will not work. You'll need to take to tech support.
Good luck.
How do i bypass password screen for microsoft surface rt
Microsoft Surface Microsoft Surface I have provided two links or you may call for help at 225-290-5733
Is there a way I can get my surface 2 to recognise the ANT pen drive for my Garmin Vivofit.
I assume it's not a surface PRO 2 but just a regular Surface 2. The surface 2 runs Windows RT which only runs specials apps designed for it. It can't run software that is made for regular Windows computers. Unless garmin creates specific software for Windows RT I'm afraid that it might never work.
You can attempt the software found here: http://download.garmin.com/omt/express/B/GarminExpressInstaller.exe but I doubt it works.
What you're trying to do it akin to runnign iPad apps on a Mac, it doesn't work before the architecture is different.
Wont boot up
Hi Lisa, because the surface is a fairly new device you should be under warranty, contact windows surface here Microsoft Surface they should be able to help you out.
Microsoft surface tirns on and logo appears but wont do amything else
To reset your Surface without logging in, please try the following:
1. Attach your Touch Cover / Type Cover
2. Power on your Surface
3. Press and hold the Left Shift key at the Login screen
4. Press the Power icon
5. Press Restart
Your surface should boot to a light blue screen with some options on it.
1. Click on Troubleshoot
2. Click on Reset your PC
3. Follow the prompts. Let me know if this does not work for you.
Surface rt is slow and freezes
Sounds like you need to do a system refresh, RT is usually quite responsive.
Swipe right to open charms menu, then click on Update and Recovery, then Recovery, then choose "Refresh you PC without affecting your files".
Good luck.
What to do when your surface RT screen is frozen and the home and power buttons are not working
just let it die then dont use it and just plug it up to charger. should be good to go then
Top Microsoft Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
