Support gave me instructions that did NOT produce any error codes.The set turns back on and works for a few more days before it turns off again...I have searched online for any way to produce the error codes to no avail.HELP?
SOURCE: Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
SOURCE: Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
SOURCE: I have a Mitsubishi WD-52327.
Replace the Lamp P/N 915PO20010 if it has never been replaced.
Mats Electronics has them for $99.00 1-800-628-1118
this sounds ilke the board maybe tring to go bad although i know it doe have colored bulbs but it has to be the circuit board this is what control the power distabution
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over
2250 posts now. All are related to
electronic equipment repair help.
Blinking codes to Mitsubishi PTVs are given in detail.
