Ricoh Aficio AP3800C Laser Printer Logo
A
Anonymous Posted on May 21, 2014
Mpc3003 "please wait" then sc670 - Ricoh Aficio AP3800C Laser Printer
Ricoh aficio mp c6000 not working from the start and give me sc 670 and not login to copy sp mode what can i so ?
Engine startup error
SC670
1. Engine does not respond within 30 sec after power on.
2. Engine down detected suddenly during power on and warm up.
IBCU installation incorrect
IBCU defective
Sudden communication reset
occurred between the IBCU and the Controller
You should be able to reset it by powering the copier off completely with the switch on the front, not the control panel, wait 15 -30 seconds, and power it back up again.
1helpful
I got sc670. what is mean and how i can fix it?
which model machine???
SC670 applies to many different Xerox machines,, but i can't help you without the relevant model
How to format hard drive through sp mode for aficio mpc3003
PLEASE ENTER THE SP MODE AND THEN PRESS 5801 TO ENTER THE FRMATTING MODE .
SELECT FORMAT HDD AND EXECUTEE.
THANK YOU.
2helpful
Ricoh mp6500 sc670 error code
sc670 is an engine startup error. A lot of times if you reset the copier (turn it off with the orange switch on the left side of the front cover, then turn it back on) the error will go away. If it doesn't the BCU board may need to be replaced.
Aficio 2045 sc670
engine respond error
fault:
after powering on the machine,a respond was not recived from the engine within the specific time
possible causes:
bicu board
controller board
1helpful
2answers
Error code SC670 shows up on my board
It’s an over load of information by the file.
Here is the actual code: SC670 mistake Engine Response.
It’s always a good idea to ask for a fix along with a question about an error code...
so what’s going on is no response from the BCU at power on; which means when the main power is turned on or the machine starts warming up from energy-saving mode, the controller does not receive a command signal from the BCU. So that could mean a
• Loose connection
• Defective controller
• Defective BCU
You can try these things:
1. Turn the main switch off and on.
2. Check the connection between the
BCU and controller.
3. Replace the controller.
4. Replace the BCU.
After replacing the BCU or controller, remove the NVRAM on the old board and put it on the new one.
If you have not worked on these units before you may need the help of a shop.
1helpful
2answers
When use adf with letter paper sise, push print botton then askme paper 5 1/2 X 8 1/2 inch´s, why do this?
is there any sensors on the adf unit, if so is the paper being feed into the adf unit, there might be a bad/defective sensor, try placing a letter size sheet on the document glass and make a copy, if it copies you have a problem with the adf, and it needs to be serviced
5helpful
3answers
Error code SC670
Its an over load of information by the file.
here is the actual code: SC670 mistake Engine Response
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
