Vehicle Parts & Accessories Logo
A
Anonymous Posted on May 21, 2014
Remove emblem HOOD EMBLEM REMOVAL
Jensen Beach Speed Shop
Level 3:
Master:
  • Master 710 Answers
  • Posted on Sep 07, 2014
Master
Level 3:
Master:
Answers
710
Questions
Helped
141075
Points
7635
Look for a retainer at the back of the emblem. If it has one, remove it. It the emblem is attached with adhesive use the appropriate tool to careful pry it off.
1 Related Answer
Anonymous
  • Posted on Dec 15, 2012
SOURCE: How to replace front grill emblem on 2010 Volvo xc70
It takes less than 2 minutes and is very easy. Just did it on my 2010 XC60 (which should work the same as the XC70). Step 1: Get the new emblem from your Volvo Part Department (approx $35). Step 2: You will need a thin flat screw driver. Step 3: Remove the old emblem by pull the center of the emblem to where you can slip the screw driver between the grill and emblem to pry it off - once you get it started you can pull it off by hand. Step 4: Install the new emblem by inserting it in the various holes where it will snap into place. Rember to be careful so you don't scrath or dent the grill on the removal step. You can do it!
How to remove hood emblem
underneath the hood were the emblem is there should be a spring lock or fasteners you can undo
2helpful
I want to remove the leper on the hood. Is there
As far as I know 2007 and 2008 US Jaguars don´t have the leper jag on the hood, instead, they have a Jaguar round emblem, ask a Jag dealer. or maybe the round center emblem of the wheels can fit there. Good Luck
6helpful
3answers
How to replace 2004 bmw z4 hood emblem
if it's regular emblem , then it has two plastic pins on the sides (Left and right , very tight fit), it's almost impossible to pull emblem out without braken it.
hood has two plastic clips ,were those pins go.
Apr 18, 2010 • 2004 BMW Z4
Nissan Xterra SE 2004 - Front Hood Emblem Removal...?
Think it got two pins held by plastic grommets
1helpful
2answers
Sticker/Decal Removal
Try a hair dryer or a heat gun. Works really well. The glue that is left behind after the decals are removed can be removed with mineral spirits.
1helpful
2answers
Front nose emblem
Incorrect on removal of the nose. You can remove the drivers side grill and reach the emblem nut. Just changed mine 1 week ago.
3helpful
Hood emblem installation
Just put the replacement hood ornament in the hole and use a pair of pliers to pull down and turn the lock 1/4 turn clockwise. It is spring loaded and if you look real close at the ornament you will see what piece to pull down and turn. Right now it is locked in its shipping spot.
2002 Nissan Xterra rear emblem removal
heat it gently with a hair dryer.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
