SOURCE: humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
SOURCE: Toshiba model 62HM95 DLP. There is a fan noise
it is just a noisy fan.
yes you can order from tosh and if you are able it is an easy fit. Just make sure you unplug the tv from the mains
Testimonial: "thank you. I at least know i can replace the fan. I didnt get an answer as to why the tv needs a fan when its off. but, thanks for the answer anyway"
SOURCE: Toshiba model number 62HM95 62' makes grinding noise
SORRY, This is from the authorized Toshiba parts center:
"The color wheel, lamp fan, lamp fan holder are parts of the LIGHT ENGINE only." It means the wheel is not sold separately and there is not even listed in the breakdown for the set a part number.
A replacement light engine (optical light engine) retails for 456.00 list and is sold on an exchange basis only.
SD TECH
