Televison & Video Logo
c
cris alising Posted on May 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv sharp model 21v-fw650s locked due to ,i forgot the passcode how can i reset it to factory setting
Need to enter the passcode my sharp tv model 21v-fw650s but the problem is i forgot the passcode how can i reset it back to factory setting or how can i open it without the passcode
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on May 22, 2014
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14985280
Points
237762
There should be a default code, that overrides the set code, and using it you can reset it by an other code. Refer its user manual to get this override code. Electro help Gopakumar Gopalan Google
5 Related Answers
Anonymous
  • 208 Answers
  • Posted on Apr 08, 2008
SOURCE: enter factory setting on LG TV
The only way I know to get into the service menu is with the LG programmer remote.
Anonymous
  • 52 Answers
  • Posted on Aug 11, 2009
SOURCE: Onida TV service code needed
press disp+vsm together here it opens service menu at last of that menu there is restore option press 1 to INT . press 1 and your tv will restore.
Anonymous
  • 97 Answers
  • Posted on Dec 22, 2009
SOURCE: Burning Smell In 19" Sharp LCD Flat Panel TV
overheating
Anonymous
  • Posted on Mar 15, 2010
SOURCE: My sharp aquos 32' LCD has a heavy green tint to
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Chi Chu
  • 8457 Answers
  • Posted on Mar 22, 2010
SOURCE: when I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
tip
Lock and Unlock most TV's
http://www.ecoustics.com/tl/17973/
Polaroid:
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
0000, 1078, 1111, 3808, 5050, 8202.
Mitsubishi LCD TV:
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view
a V-Chip locked program, view the locked TV, cancel
the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked
TV without entering your passcode. When your
password is requested, press the number 9 and QV
buttons on the remote TV control at the same time.
This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process
deletes your old passcode and prompts you to enter a
new passcode.
AOC: 0,0,0,0
LG: 7,7,7,7
PHILIPS: 0,7,1,1
SONY: 4,3,5,7
VIZIO: 0000, 2489, 5351, 8202, 8205, 8206
Emerson/Sylvania/Funia: 0000
NOTES from Emerson/Sylvania/Funai:
1.Make sure to enter the exact same new password in the
"Confirm Password" space as one in the space. If they are
different, the space is cleared for reentering.
2. Your password will be erased and return to the default(0000) when a power failure occurs or this TV has been
unplugged for more than 10 seconds. If you forget the password,
unplug the power cord for more than 10 seconds to
restore the password to 0000.
Sharp TV:
Sharp LCD TV Clearing the secret number using the remote buttons and the TV's buttons.
If you forgot the secret number, clear the secret number using the following procedure:
1) Press MENU, and the MENU screen displays.
2) Press Left/Right arrow buttons to select 'SETUP'
3) Press UP/DOWN arrow buttons to select 'EZ setup', 'CH setup', 'Parental CTRL' or RESET, and the SECRETNUMBER INPUTSCREEN DISPLAYS.
Press and Hold both CH UP and VOL+ ON THE TV SIMULTANEOUSLY until the message appears on the screen. The SCECRET NUMBER IS ****.
on Aug 17, 2010 • Televison & Video
tip
Bypass V-Chip Mitsubishi TV
Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV.
To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
on Mar 20, 2010 • Televison & Video
My sharp TV po ako nka limita kopo ang model 21v-fw650s
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1helpful
SHARP TV 21V-W70M CHILDLOCK RESET
TV sharp premo ret race line model no 20 W 70M
4helpful
My vizio has input locked
Hello
Reset the device to its factory settings. To reset it to factory settings, enter "Setup", select 'Reset All Settings", press [=>] button to reset the TV to its factory settings. All parameters, except the parential lock will be reset to it original factory settings. If you for got the pass code, just enter its factory reset passcode [0000]; Eventhough the set will report this to be wrong passcode, input [0000] once again. This will unlock the passcode, and you have to set a new passcode. OK.
1helpful
Forgot the password to tv
Good Day,
Bypassing the V-ChipLock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
When changing or deleting your passcode, you must use the remote control included with this TV. You cannot use any Mitsubishi remote control from another component or a "universal" remote.
Good Luck, Big Irish.
2helpful
2answers
V chip codes
LauriJo...
From the back of my Mitsubishi Owners Manual, Appendix A
"Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time when your passcode is requested. This process temporarily unlocks the TV.
When entering the V-Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode."
I hope that helps you.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
