It prints and copies but i cant even find a scanning option
Don't know if you have tried this, but it might help.
Create a scan to PC profile
1 Type the IP address of the MFP in the address line of your browser, and then press Enter.
If the Java applet screen appears, click Yes.
2 Click Scan Profile.
3 Click Create Scan Profile.
4 Select your scan settings, and then click Next.
5 Select a location for saving the scanned output file somewhere on your computer.
6 Enter a profile name.
The profile name is the name that will appear on the Scan Profile list on the MFP control panel.
7 Click Submit.
8 Review the instructions on the Scan to PC screen.
A shortcut number was automatically assigned when you clicked Submit. You can use this shortcut number when
you are ready to scan your documents.
a Go to the MFP, and place your original document in the ADF face up, long edge first.
b Press # followed by the shortcut number on the keypad, or touch Profiles on the home screen.
c After you enter the shortcut number, the scanner will scan and send the document to the directory or
application you specified. If you touch Profiles on the home screen, locate your shortcut on the list.
9 Return to your computer to view your file.
Your output file is saved in the location you specified or launched in the application you specified.
Good luck.
SOURCE: Lexmark X1185 (print trio) does not scan or copy since upgrading to Vista
I had the same problem. Fixed it by reinstalling the drivers for the motherboard (USB drivers in particular). Hope this helps.
Bill Scott
Dixmont, ME
SOURCE: scanner not workin-lexmark x1240
Which operating are you using if your using (Vista use windows photo gallery to scan)
SOURCE: Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
The Vista drivers available on the Lexmark website do not contain the All-In-One Center. They are minimum drivers. Although the scan drivers are shipped with the web package, they cannot be used by the All-In-One Center since it is not included. Please use Windows Scanners and Cameras or Photo Gallery for Scanning.
