My PS2 will only play PS1 games, please help.
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact [email protected]
SOURCE: PS2 reads ps1 games but not ps2. Clicking noise
Hi Jstpd,
Boot up your PS2 with no disc in it. Press the Traingle and highlight the top selection. Press the triangle again and then press X then select ON and press X. This should turn on Diagnostics. Do not reboot the PS2, just put a PS2 disc in. This might get it reading PS2 discs again.
If this does work you can follow the procedure for cleaning below:
SOURCE: ps1 games
Are you receiving a disc read error? Or do they simply not load?
In either case, you will want to make sure that your laser is clean. This will require opening the console.
Just google playstation 2 repair and look for free walkthroughs...they are everywhere.
I would boil the problem down to 3 possibilites....
1. Alignment
2. Adjustment of the cd side of your laser potentiometer
3. A simple cleaning of your laser
SOURCE: ps2 games to play on ps3
you can only play ps1 and ps2 games on your ps3 if it has the same game region.hope this info helps your problem
looking for 1 book new from factory that has cheat codes for PS1 & PS2 games
