I have a Maytag performance dryer model PYE4500AYW that was running fine and suddenly just stopped and would not restart. Any suggestions for what could be wrong? I checked the breaker and the plug, both are ok.
why,what's wrong with the door that it doesn't close,i mean is it not locking,is the door gasket bad or not there?are the hinges bad?what do you mean by getting it just right?all you should have to do is close the door,the strike on the door goes into the catch and latches the door closed,is the plastic catch broken,if so the door won't stay closed,if the hinges are bad you can't get them for this dryer anymore.you can go here,put your model number in and go to where it says door and you can see all the door parts,if it's closing but air is getting through the door the gasket could be bad
https://www.searspartsdirect.com/model-number/pye4500ayw/3048/0151200.html?searchType=modelSearch&q=PYE4500AYW&searchTerm=PYE4500AYW
Are you getting any power to unit? The power supply most likely overheated and burned out a capacitor. It is possible that the relay may have gone bad to.
i lifted up the top and unscrewed the front of my maytag dyer pye4500ayw a very thin belt was at the bottom. who do i replace this belt and where does it go?
check your door switch. if it is ok, get this kit part number LA-1053. This is a very common solution for this dryer. the thermostat fix kit will contain a thermostat and two other parts....one is for gas and the other is for electric. just read the instructions and you will know what one is for your dryer. these parts can be accessed by lifting the lid and looking to the rear of the cabinet past the drum. MAKE SURE TO UNPLUG THE DRYER FIRST
