When I turn my camera on the power light flashes and i have a red symbol appear on the lcd screen. I have also noticed the screen has F14 on the right hand side im not sure if this has anything to do with it but i have never noticed it before. after a few seconds the camera turns itself off.
The red symbol is the erasure prevention slider on the tape. check it's not on or push the slider on and off prevention. this should fix the red symbol, you might have to do it a couple of times before it works. not sure what F14 is can't find it in the manual. try the solution here. if it still turns off after a few seconds i have another way to fix the power.
If the flash is not functioning, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it. If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings. When shooting movies. When shooting in the Twilight or Handheld Twilight mode. When shooting with the Burst or Multi Burst mode. Shooting with the Fireworks or high sensitivity mode. (ISO) Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications. Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery. This should resolve the issue.
Your
camera has a built in flash function which enables you to take photos when the
light condition is not good. 1.
Press the Up button. (for reference of buttons, please see the below figure mentioned) 2.
Press the Up button once until you see the icon appear on the LCD screen. This
indicates that the flash is forced on. 3.
Press the Up button again to change to the auto flash function. 4.
The icon will appear at the top of the LCD indicating that the auto flash is
turned on and ready to use. 5.
Press the Up button again to change from the auto flash to the red eye
function. 6.
The icon will appear on the LCD indicating that the red eye reduction function
has been activated. 7. To turn
off the flash function, press the Up button again until the icon is displayed
on the LCD. Note: A
“Low Power” message will appear on the LCD screen, if you select the flash
function when the battery power is insufficient. To continue
using the camera with the flash, please change new batteries
Touch the lightning bolt icon area until the flash icon appears on the left side of the display. This will activate the flash.
Touch the lightning bolt icon area again until the flash symbol appears on the LCD screen. This forces the flash function.
Touch the lightning bolt icon area again until the eyeball icon appears on the left. This activates the red-eye reduction mode.
To turn off the flash, touch the lightning bolt icon area again until the no-flash icon (lightning bolt inside a circle) appears on the left.
This is covered on pages 13-14 of the manual. If you've misplaced your manual, you can download one from the manufacturer's web site at http://vivitar.com
You should be able to turn off your flash, or change the flash to a different flash setting by using one of the buttons on somewhere on your camera. The proper button is identified by the flash symbol, that looks the same as the one on your LCD screen, a jagged, down ward facing arrow, that looks something like a bolt of lightning. Simply press this, it will ether change the setting on your LCD, or bring up the settings that you can change manually by selecting whatever setting you want for the flash.If you don't want to change any of the settings, but want to clear the symbol off of your LCD screen simply hit the Display button that will hide those icons from your view and can be seen again simply by hitting display once more. I hope this is of some help to you, if not, consult your user guide or manual that came with the camera, it should explain exactly what to do. I hope that you have success, God bless...
1. Turn OFF cam 2. Remove the battery or the power supply 3. Turn the switch to CAMERA for about 30 sec 4. Turn the switch to OFF 5. Install the battery or power supply 6. Turn the switch to MEMORY 7. Open the LCD cover and press the RESET button ( small inner button ) 8. You will be prompt to adjust date/time. Do it 9. Take some pictures
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
