Reset password
SOURCE: reset bios password
If you are not afraid to open the box, the simple fix would be to remove the cpu battery(looks like a quarter) for about 30 seconds and replace, then boot up. At that point it will ask for information such as date and time, but then you can access the bios
SOURCE: Dell D505 BIOS Reset
Generally, all you need to do is get on to Dell Support and get in a chat with one of their people and tell them that you are locked out by a BIOS password, and needed to get around it. After they verify that you are the owner of the laptop, they should give you a password that gets you through it.
SOURCE: how do I reset bios password on a used dell 710m
For you to reset the bios all you need to do is to take it out, but before you do that you'll need to power off your laptop.
Regards
SOURCE: dell studio 1737 laptoplost BIOS password called
BIOS password is NOT able to be Cleared by taking battery out, is stored in NVR. Is impossible to hack, crack, unless get special DELL code. Must contact DELL. provide proof of ownership, a receipt etc, then they will send you special code to enter. OR look for pay For site on internet.
SOURCE: reset bios/cmos password
on the bottom of the vostro 1510 there is a large panel that covers the hard drive, wifi card, and cmos battery connector. remove the cover unplug the red and black wire connector and remove the battery. also make sure the system is unplugged from power. i waited about 5 mins and pushed and held the power button for about a min. after that plug the main battery in and test to see if your password has been removed
