SOURCE: Panasonic PT-52LCX66 Television lamp reset time
With tv 0n press vol- (minus) on tv and hold. then hold 0 on remote hold both for about 5 sec.
SOURCE: reset lamp counter on PT-52LCX66/PT
i aswell dont have PIP on remote but i found another way to fix....
hold the volume button ON TV - down and the 0 zero button on remote at same time :) just worked for me...
SOURCE: need to reset the lamp time on my PT-52LCX66
To reset lamp timer in Panasonic PT-52LCX66..
Press and hold Volume Down button on TV front and press and hold 0 (zero) button on TV remote at same time for 6 seconds, a lamp reset message will appear on TV screen.
Thanks.
SOURCE: The lamp hour meter needs to be reset for
This works for most Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
SOURCE: where do i locate lamp in my panasonic pt 52lcx66
The left speaker grill comes off then the lamp door will be behind there. Mind you if the lamp in your TV still works and you are changing it. Make sure that you let the TV cool down for a minimum of an hour before handling the old lamp. Also your lamp part number is TY-LA1001. Please take a moment to rate my answer. Thanks...
Testimonial: "Rite on thanx"
