SOURCE: how to reset the unit...
press and hold the following buttons in the sequence below.
(1) Stop/clear, (2) start, (3) exposure lighter, (4) exposure darker, release the 4 buttons and press the stop/clear button again. the display should now indicate 000.
below the display are 3 buttons... press the left button once, the middle button 6 times, and the button on the right 3 times. the display should now indicate 163.... press the start button 3 times.
your machine will now restart, and if the code was as a result of a power problem, should now work fine. if not the problem could be related to the fixing unit, power supply, or one of the boards.
Also do not tamper with any settings while in the service mode, this WILL have undesired effects. TAKE NOTE, this will only work if your model is the KM-1500
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
SOURCE: blingking code C-6 in my kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
SOURCE: kyocera model km-1810 laser copier error code a400
MOI BARNI TECHNICIENT
CLIC SUR TOUCHE GOUCHE ET STOP ET TOUCHE VERT AU MEME TONS OK APRE MACHINE C4AFICHE U.000
APRE ENTRE U.20 PRINT ET TOUCHE AUTU MATIQUE APRE TOUCHE PRINT VERT BON CHANCE
SOURCE: photocopies displays and error message that reads 400 then C-6
It most likely can be reset over the phone. Go to www.gfbm.net and call. They can walk you thru reset over phone whach should correct the problem at no charge.
