Assuming the restart option isn't available after pressing and holding the start button for a few seconds; you can let the battery drain ... but it may take a few hours. (Adapter must be unplugged). Then connect the adapter and restart. Another way is to remove the battery.
After the tab restarts check if system updates are taken care of. If the problem happens because of a particular app consider to uninstall that app.
The issue isn't with the tablet, it is something in your Wifi...there are a number of things that it could be, try simply rebooting your router, that would be the easiest thing to try. If that doesn't work, try switching your tablet to "airplane mode" , and then try to connect...
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
I called Asus. Told to connect charger & hold volume up & power for 40 seconds. Nothing happened, then press power & volume down. Nothing happened. Then told to hold volume up & power for 60 seconds, and it should come on, which it did.
Are you able to connect to the internet through another device (TV, Blu-ray player, gaming console, computer/laptop, etc)? If so, how do you connect? I believe it's asking you for your network password, in order to connect to your network, which if you do not know, you can work with your Internet Service Provider, or call Asus Support for further assistance.
