LG 37LC7D 37 in. LCD HDTV Logo
A
Anonymous Posted on May 23, 2014
Lost freeview radio channels from 710 to 723 - LG 37LC7D 37 in. LCD HDTV
WHISTON PORTABLE APPLIANCE TESTING
Level 2:
Champion:
  • Expert 203 Answers
  • Posted on Jun 22, 2014
Expert
Level 2:
Champion:
Answers
203
Questions
0
Helped
39201
Points
422
If you go to settings and do an auto set up it should find them for you make sure you have a good signal first
1helpful
I Have a 15inch acoustic solution telly with built in freeview model number astv15id , however it has lost most of the freeview channels how do i retrieve them back.
Go into main menu set up and navigate to option to rescan. (might be called install or re-install stations)
Note - if it has lost channels it may be due to poor signal quality - check the quality of your aerial connections. You may also have lost channels if your area has recently been subject to 'digital switch-over' . Although they are already on digital tv all Freeview boxes will need re-tuning after switch over because this entails a change of some channel frequencies post analogue.
Feb 26, 2011 • Music
1helpful
Lost our freeview. New TV in bedroom (Sharp LCD, LC-19SH7E-BK), which has freeview and was working fine. However, we set up a magic eye so we can have SKY (which we can now use through channel...
if you have connected your sky box as per instructions, putting the aerial coax to it and a fly lead(as in a male to female coax as used on a vcr to tv) from the output to the tv's aerial input, then disconnect the aerial from the sky box and put it back to the tv. The skybox will weaken and even loose the signal.
I have lost all my freeview channels on my Sony Vaio VGC-VA1,I have tried numerous times to re scan the channels but with no luck,this happened this week end
After the recent retune that all Freeview customers had to do (which failed miserably) this can happen on TV tuners on your pc's aswell.
Try uninstalling the product, and reinstalling, then rescanning. There is a chance this could work.
2answers
2helpful
Lost ITV channels and C4
I've got exaclty the same problem :-/
HELP!
2answers
Freeview probs
can you try a external antenna on it?
I have the same problem, can anybody help?
Techwood freeview
Any luck? I lost channel five to channel 802. I want to change it back to it's slot after channel 4
2answers
I have lost my tv channels!
I have a philips freeview box (although it is not built in). I recently lost all my channels also. It took me back to the installation screen and started to look for channels, furthermore if it couldn't find any it 'bugged out' on me. The only way I got around this was by unplugging the aerial, watching the screen trying to scan the channels and when the progress bar / channel # was near the end plugging the aerial back in. For some reason this started the scanning over again but this time it found channels! Strange I know, but maybe its different for me and one of those conspiracies that they program products to fail after a few years to make you buy more. Try this and let me know if it works Thanks Matthew
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
