1. Make sure you have good batteries in the remote and they are installed properly.
2. Press the DVD button on the second row of the remote, then check if the Power and other buttons on the remote work with your system (it probably won't since the factory setting is for a Sony DVD player, not a home theater system).
3. If it doesn't work you need to find the correct code number for your system and enter it into the remote. Press and hold the SET button for more than 3 seconds until the SET indicator lights up. Keep holding the SET button down and press the DVD button, then release both buttons. Then enter the code 31622. If you have done this correctly the SET indicator flashes 3 times, if not start over.
4. See if the remote now controls the theater system correctly. If not, repeat the above procedure #3 with the following codes one at a time until you find one that works: 31558, 31658, 31758, 31822, 31858, 32522.
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
SOURCE: sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811
RM-SP350 REMOTE CONTROL
SOURCE: universal remote
You can try a code seach which many universal remotes will do, this may be called auto search, if you have the manual for the RCA see if it is listed, instead of entering a 3 digit code, you cycle through all codes until the correct one responds to the unit you are trying to program.
SOURCE: My Sony DVD Home Theater
Specs and manual:
No.
http://www.retrevo.com/support/Sony-DAV-DX255-Home-Theater-Systems-manual/id/750dj490/t/2/
Remote available here:
About $51 delivered
http://cgi.ebay.com/Sony-parts-147964111-RM-ADU003-REMOTE-CONTROL-/360325260367?pt=LH_DefaultDomain_0&hash=item53e50f244f
about $58 base price
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=RM-ADU003&uuid=A12956152737951
