After years working OK, the camera will not accept ANY memory card - just gives a "Memory card error". I had accidentally tried putting the card in back to front, realised it wouldn't fit and put it in correctly. Could it have damaged the socket somehow? If so, is that a repairable problem?
Yes you can have dammaged the contacts in the memory card holder.
The some or all contacts could be bend, or even the switch (feeler notch) can be pusshed in or broken.
It is difficult to explain, that is why I also put a picture inhere.
You should use a light, and a magnifying glass to look in your camera.
The picture is from a memory card reader, but in your camera it should look the same. You can see nine contacts, and to the left on the picture you can see they look like a triangle. All contacts should look like thatand not one is allowed to be bend or have a dent.
When you look in the memory slot, to the right (not on the picture) you should see a little notch. That is the notch that reads the lock switch. Telling the camera the card is locked or unlocked.
If that part is missing, or broken, or inside the camera that switch is dammaged, your camera will keep telling you there is a card error.
Waht could you do?
If one of the nine contacts is down, toy could try to get it up again, perhaps with a small needle. But please don't open the camera. You could do even more damage, if you are not skilled in that. If you can't fix it, contact a pentax certified repair centre and ask them what it will cost and how long it will take to repair.
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Ok try this for you to determine if your memory card is defective or not, try to insert your card to a device that support the type of memory card you have. Then if it still doesn't work i assume your memory card is defective. But if the memory will work try to insert other memory card on your camera for you to determine if your camera memory slot has a problem.
Reply to this post post if this helpful or not and dont forget to vote
Tnx for using Fixya
Hi, have you tried using your computer to format the memory card, what you need to do is put your memory card into a memory card reader then wait a minute then open up my computer then locate the memory card then right click on it with the right button on the mouse then choose format and format it to fat32 then try it in your camera and it should then be working.
if you have been using a memory card in the camera and still have it then put this in the memory card reader and go to my computer and then right click on the memory card and select properties and have a look at what format that memory card is, and if its anything other than fat32 write down what it is. Then put the new memory card into your card reader and goto my computer then right click with the mouse then choose format and then choose to format it to the same type as the other memory card thay you know works in the camera, once you have done this the memory card should work in the camera with no problems.
until you have formatted the memory card to the correct type it wont be recognised by your camera so give it a try what i said and you should find you will have no more problems ok.
Some cameras will not work with the larger flash cards. Also the SDHC requires an adapter that accepts the high density. Many built into the computers do not accept the high density and will demand they be formatted. Verify the requirements of the devices you have for compatibility.
Please format memory card by going to camera Menu options in
DZ-BX35E and try. If problem still exist, then memory card slot could be damaged. Check new memory card in other camera to verify that card is OK.
Hi, don't know if this is any help, but i had the same problem with trying a 1gb card, i think that this camera will only accept up to a 512mb! If you go higher it will not accept it. 512mb is highest memory card you can go with this camera! Take care and good luck. Kerry
I had exactly the same problem with a 2 year old LX-1. The card worked fine on the computer, formated no problem but would not work in the camera.
I took a can of air and used maybe 3 one second bursts to blow out the card slot. Card immediately started working.
