Question about Maytag Neptune MAH6500A Front Load Washer
Model MAH-6500 Neptune Washer. Unit is 4 years
Model MAH-6500 Neptune Washer. Unit is 4 years old. Recently started getting LO code after wash cycles completed. If I unplug and wait >2 minutes (per manual), I can usually get door open after soem effort. I can hear cycling taking place as if to unlock. Getting door to open after resetting is hit or miss.
6ya staff
SOURCE:
Anonymous
SOURCE: Maytag Neptune Error COde "nd"
I had the exact same problem. nd code (no-drain) at the end of the cycle and when I opened the door the machine was still full of water. I took the back panel off the washer and disconnected the drain hose from the pump. (You're going to get quite a bit of water gushing out at you so be prepared with towels or a shop vac.) At this point you should see a little rubber disc over the end of the section you just exposed on the pump. This is a little drain flap. Just lift it up and you should be able to see into the pump a little bit. At this point I poked around in there with my finger and found a hair pin stuck in the pump! I wasn't able to get it out from this end of the pump so I disconnected the big rubber boot which connects the wash drum to the pump. Then I was able to twist the pump (counter clock-wise) and release it from the washer base. I didn't have to disconnect any wires and was then able to see into the other side of the pump and pull the hairpin out. Put everything back together and it's worked fine ever since. I've never even looked inside a washing machine before but it really was really fairly simple. Now my husband really does think I'm a domestic Goddess. I said he should take me out to dinner with the money we saved on a service call!!
Posted on Mar 18, 2009
Anonymous
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
Posted on Jun 28, 2009
Anonymous
  • 56 Answers
SOURCE: mah 6500 spins but leaves som water in tub. if you
they have a balance ring on the front of the tub and it's full of water
Posted on Jul 03, 2009
Anonymous
SOURCE: Maytag neptune washer mah 6500
why is my washer leaving brown black lines on my clothes
Posted on Sep 08, 2009
mrbobfixit
Robert DeStevens
  • 259 Answers
SOURCE: generally, how many gallons does
About 14 gallons on average. More depending on absorption of clothes in tub (cottons will soak up more water).
Posted on Aug 18, 2010
Ou Maytag Neptune Washer MAH-3 will not drain.
This problem was answered a couple of years ago in detail. A search should produce it. Search the name Scruggs.
Sep 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
We have a Maytag Neptune Washer Model MAH-1, approximately 5 years old. Never had any problems previously. Last wash, noticed a loud grinding sound upon starting the cycle. I stopped the wash, and...
Sounds like the spider arm(s) are broken in your machine. It is the part that supports the wash drum in the machine. It's a major repair job and can be expensive to fix. Get a few estimates before deciding whether it is worth fixing or replacing the washer.
Oct 05, 2010 | Washing Machines
Mah 6500 spins but leaves som water in tub. if you
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Dear kim,
ngfam at you service!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Aug 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
My Neptune washer MAH9700
I have a Maytag Neptune MAH 9700. It died one day and the door remained locked. I am guessing the circuit board is fried so it's a good thing I purchased a five year extended warranty. The problem though, is that my 2 year olds BLANKY was in there and she won't go to bed without it. Can't wait 2 weeks for the repair guy. I was able to remove the top and (after I unplugged it of course) get my hand to the bottom of the switch housing. Seems there is a small opening at the bottom. I pressed up with my finger and was able to get the door opened. Whew!!! Hope this helps. ; )
Jan 10, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
164 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
