Question about Dell Computers & Internet
WES 5000 Portable wireless speaker system--- how do you hook it up to TV???
Just received it in mail today, no instructions how do you make it work on your TV ? My Husband has hearing problems and I want to place these speakers next to his recliner, so that the volume on the TV can go down .
    Top Expert:
  • Dell Master
  • 3,698 Answers
See if you can get an operations manual:
www.royalsupplies.com
Posted on May 24, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: Treo 650 2yrs old - speaker problem
The problem is a hardware problem. There are a couple of solutions. One is to disable the output jack. This is a hardware solution. You can get Volumecare which will boost the sound but this didn't work for me. Or you can cheat, get your Treo covered under a repair program and make them actually fix it for real.
Posted on Nov 10, 2007
Anonymous
SOURCE: Motorola A1200
I had the same issue. I got a replacement flip top for my phone and it worked for 5 minutes and then started happining again. so i took it apart again and used the brown ribbon from my new flip speaker and solderd it to the two points on my old flip. that worked for 5 min or so and now im still having to use speaker phone. what the hell could it be?
Posted on Nov 05, 2008
Anonymous
  • 4 Answers
SOURCE: speaker no sound
In the socket where you plug in the external earphone are bending contacts, which also switch of the speaker when you are using an earphone. Try either putting in the jack and wobbling and twisting it, or tapping the corner with your knuckle.
IN EITHER CASE - BE GENTLE
That will knock of the dirt and the switch will work again
Posted on Dec 17, 2008
anasmaq
Anas Al-Mustafa
  • 100 Answers
SOURCE: wireless speakers to audio devices having no audio output
you can find all kinds of adapters for RCA or phone jack to anytype of connectors at best buy or circuit city, if not Radioshak probably have them. just ask for a cable adapter to the type of connector transformation you need for the speakers.
Posted on Dec 30, 2008
Anonymous
  • 6 Answers
SOURCE: speaker not working
More then likey you will have to perform a master reset to the device
Posted on Feb 04, 2009
Can i use wireless speakers with this system
Yes but only if the hi-fi unit either has a built in wireless transmitter or the wireless speakers arrived with a dedicated sender unit to plug into the hi-fi or tv or whatever you need to use them with.
I suggest you begin by reading the two relevant instruction booklets or finding the specifications online.
If there is no sender unit it might be possible to buy a generic wireless sender unit.
Jun 26, 2016 | Sony STR-DH130 2 Ch Hi-Fi Receiver...
How do i wirelessly connect the reciever to the speaker system/tv?
You'll want to research an adapter for this. Radio shack probably has one of the most inexpensive units available today, but you can find others online, with better quality sound. Start with a google search for what you are trying to do. Google, "how to connect speakers to stereo, wireless".
Keep in mind, not all speakers are created the same. Some have amplifiers in them and some do not. This will change the type of adapter you will need.
Fairly new adapters on the market may transmit audio over a wireless network or even Bluetooth, you will need to research your receiver and/or tv to see if either of these are options for you. Another common thing is a range of branded theatre A/V sound systems with wireless sub woofer and/or back speakers.
Good luck with this, it should be a fun project.
Apr 30, 2014 | Panasonic Se-fx50 Digital Receiver
Trying to bypass module for wwireless speakers.. Is there a code??
No. If the system came with the wireless rear amp, then it will not work without it.
Jan 18, 2013 | Samsung Wireless Receiver Module Swa-4100...
My TV reads "Your receiver is currently off. Press select to watch TV" The receiver powers up fine, but none of my remotes nor the front control is able to move the receiver past this screen. Receiv
Please make sure the receiver is plugged directly into the wall, bypass any power strips. Make sure the remote has fresh batteries inside, press and release the SAT button and then press the select button. If the remote is not working, go to the receiver and try the select button and try to channel up and down. If you have any further DISH questions please e-mail me: michael.houston@dish.com
Nov 29, 2012 | DISH Network ViP622 DVR DTV Receiver /...
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
How do I conect external radio/speakers to my lg 42lh40-ua
There are many options here. Most HDTVs today have analog audio and digital audio output jacks. You can use RCA audio cables or a 3.5mm connector, whichever your HDTV has to connect the analog stereo output of the TV to any number of devices such as a stereo/amp which has speakers attached. You could also connect an FM transmitter to the TV and send the audio wirelessly to a nearby FM radio, boombox, portable etc. Most HDTVs today have a digital audio output, typically optical, which uses a digital audio cable ($15) to connect to a surround sound receiver. You can also connect the stereo analog output jack on the TV to a 2.4GHz transmitter and receiver speaker combo to get wireless audio outside, in a swimming pool and so forth, all around the house using wireless speakers. These setups usually cost around $150 or so. Look for the jack on the TV labeled AUDIO OUT and see if it is the white and red 2 jack ports or the smaller 3.5mm single jack port. Adapter cables are available at Radio Shack for around $10 should you need them. So you see the options are almost endless.
Aug 17, 2010 | LG 42LH40 LCD TV
I can't get the video to work on the wii using the red, white & yellow cables. Will component cables fix my problem?
Your post indicates the use of a receiver. If you are in fact using a receiver, make sure you have a "video out" connection from the receiver to your television. Then make sure you have the correct input selection on the receiver, and on the TV.
Dec 28, 2009 | Yamaha RX-V463 Receiver
Connection help with receiver and lcd TV
depend on what you wants to do. if you wan to get sound from your tv on receiver connect out from tv to in on receiver if U have optical out from tv send this to optical input on your receiver and set up your receiver to impute to digital HDMI carrie sound and video...
(My Denon receiver set-up shows an HDMI cable going from the Video Out on the TV to the HDMI MONITOR OUT on the receiver)
OUT TO OUT don't make sense ...could be out to impute you may have HDMI going from receiver to TV and other HDMI imputs on receiver to use receiver as distribution unit say you have satellite HDMI, DVD HDMI, Computers HDMI IMPUTE all of this connected to your Receiver and the HDMI monitor out from your receiver connected to TV so now you may select any of this sources to wach In your TV and lessen trough receiver speakers
Apr 10, 2008 | Sony BRAVIA KDL-40V3000 Television
Home theater set up
I want to download instructions to record tv shows while I am gone for a day or two,on my sony model#kdl-46xbr2. e-mail bmllrctg@yahoo.com
Dec 27, 2007 | Televison & Video
Open Questions:
Dell Printer@^+[1]=855-221-4867@&@tech Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
Ekse
Clive
Clive
Alun Cox
