Question about KitchenAid Food Mixers
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
  • 145 Answers
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Posted on Jul 08, 2009
6ya staff
SOURCE:
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
I have the KitchenAid 5 Qt HD Professional stand mixer. When I securely attached the bowl to the bowl support arms (I hear the bowl click to the back) and use it to knead bread (the flour amount well...
hello step ..... yes. You may have to adjust the height of the bowl a wee bit as it sounds like the dough hook is hitting the side of the bowl..
It tells the steps in your manual.
Easy to do.
If you don't have the manual you can download it for free here http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
Joe
Mar 12, 2011 | KitchenAid K5AWH Stand Mixer
Mixer makes a clicking noise and beater stops turning or mixing...gear seems to be slipping...
The only part that consistently wears out is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out and becoming chipped. The clicking noises you hear are made by the Worm Gear banging on the Follower. All the teeth of the Follower are now damaged and the Planetary stops rotating.
Removal and replacing of the Worm Gear Follower is no easy task. Let me know if you need help.
(Do not try to remove the Planetary assembly by forcing it with a screwdriver. That is not how it's done.)
Jan 23, 2011 | KitchenAid KP2671 Professional 6 Series...
I just got my mixer a few weeks ago for Christmas. I have made cookies twice. My problem is that the bottom of the bowl doesn't get scraped. The first time, I ended up putting more flour in the dough...
Put the flat beater on and mount the bowl to the machine. Now look for the screw next to where the beater mounts on the head- this is the adjusting screw. Turn it counterclockwise to lower the beater, just a quarter of a turn, and then check where it's running in the bowl. Repeat as necessary. If you need to raise the beater, just turn the screw the other way.
lp
Jan 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Problems mixing thinner batters thoroughly
Try a higher speed , this should force the batter out using the centrifugal force generated
Aug 18, 2006 | Electrolux 450 Watts DLX-N24 Assistent...
Food Mixers Logo
678 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
