NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
A
Anonymous Posted on May 24, 2014
Blue wireless not flashing
The blue wireless button is no longer lit up, we cannot access wifi with other devices. . how do I troubleshoot
Level 3:
  • NetGear Master 7,733 Answers
  • Posted on May 07, 2015
NetGear Master
Level 3:
Answers
7733
Questions
0
Helped
1864685
Points
21487
Seems the cable is not working. Try to find another cable.
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
where is the WPS button? - Canon Community
community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
1helpful
2answers
I don't see any WiFi connections in my computer (Windows 7) and WiFi indicator infront of laptop does not lit. Troubleshoot shows "Wireless capability is turned off". The switch in front of PC is turned on...
First, turn the wireless switch OFF and switch it back ON
(make sure sure that there is a BLUE light on the wireless indicator)
then press Fn+F5 (this will ENABLE the wireless capability of your computer)
>Try to detect wireless networks
>comments suggestions ratings and violent reactions will greatly be appreciated
1helpful
2answers
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
3helpful
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
58helpful
4answers
Samsung wep410
As Quoted from Arfur - see bold print if you are having problems. You don't need to unpair the other phone, it will unpair itself.:
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
