Jenn-Air JED8230 Electric Cooktop Logo
A
Anonymous Posted on May 24, 2014
How do I remove a jenn air exhaust fan motor switch? Model # Jed8430BDB
5 Related Answers
Anonymous
  • 66 Answers
  • Posted on Jan 14, 2008
SOURCE: Jenn Air Not Exhausting During Grilling
is this down draft cook top or give me the m# thanks
tarl107
  • Posted on Jun 18, 2008
SOURCE: cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Anonymous
  • 59 Answers
  • Posted on Jun 26, 2008
SOURCE: exhaust fan not starting
Hi
I have all the diagrams for that model and will gladly send them to you all for free via email. Remenber that the fan will always get gresse and have to be clean, also keep the filter clean.
Let me know were to send the diagrams...Glad to Help!!
Eddie Rentas
Tupper Lake NY
Anonymous
  • 135 Answers
  • Posted on Feb 17, 2009
SOURCE: Jenn-Air electric burner goes to full no matter what the setting
This would be a faulty switch. Hope this helps!
Anonymous
  • Posted on Oct 06, 2009
SOURCE: JED 8320 fan and burner switch
http://www.whirlpoolparts.ca/index.php?PHPSESSID=f2330dc59be8bdd5f5463d5e0d1362f9
Electric jenn air cooktop shocking me JED8430BDB
Knob is probably split/damaged and the hi voltage from igniter is running through it , remove knob inspect it and clean or replace it.
Uninstallation of Jenn-Air JED8430BDB cooktop
There are 2 clips under the cooktop, attached to the counter.
Remove the drawers under the cooktop to see the clips.
The left top element is not working, the control knob lights up but doesn't heat. Is it the element or the switch? Mod#JED8430BDB Ser#1414040011A Schott Ceran
It could be either. The only way to properly check is by dismantling the cooktop and checking the circuit with a volt meter or test lamps.
2helpful
I am looking for an owner's manual for a Jenn-Air JED8430BDB. Can you help me. . Thank you.
I uploaded the owners manual.
Repair information is here
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47639&diagram_id=653174#d653174
Jenn Air Cooktop wiring issue.
Thank you for your enqiry!!
Mar 21, 2009 • Cooktops
1helpful
Cooktop fan switch replacement
Exhaust fan not starting
Hi
Eddie Rentas
Tupper Lake NY
Jenn air model JED8430bdb
A similar concern on a different model (8230):
To my knowledge, the:
green - ground
white - neutral
black - 120 to ground
red - 120 to ground but between red & black, it should be 240. A Jenn-Air JED8230 requires a 3-wire, 120/240 Volt, 60 Hz Outlet.
Pls consult/confirm with your local electrical utility/codes the availability/applicability of this power/wiring system or reference National Electrical Code, NFPA No. 70
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
