Question about Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX VR Zoom Lens
Nikon lens 55-200 nikon dx vr
Lens clicks after taking photo in vr
  • 146 Answers
So does mine, that is the VR releasing, it is normal.
Posted on Jul 05, 2009
6ya staff
SOURCE:
Nikon d5000 really dark
go into settings an change the lighting
Aug 10, 2012 | Nikon / D5000 VR KIT 18mm - 55mm AF-S DX...
The lens clicks twice and vibrates after each photo is taken. It doesn't happen when the VR is turned off. I didn't do this when new.
First, try carefully cleaning the lens and camera body contacts.
If that doesn't work then sorry, that's a fault which cannot be fixed on a DIY basis.
Either live without VR or send the lens to Nikon for repair. If it's under warranty then the repair will be free as long as it's not found to have been damaged by misues (such as being dropped).
Mar 09, 2011 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
My Nikon 18-55 mm lens turns easy when zooming in, but is stiff when zooming out. There is no roughness in the movement that would suggest dirt.
hi there,
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Dec 12, 2010 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
Nikon Nikkor 55-200mm f/4-5.6G ED IF AF-S DX VR Vs. Nikon Nikkor 55-200mm f/4-5.6G ED IF AF-S DX are they the same len or not? thanks, Ricky at rpotter@eatel.net
No. The VR lens has 15 elements in 11 groups, the other has 13 elements in 9 groups. This indicates that the two lenses have different optical designs. The main difference, however, is that the VR indicates "vibration reduction." This lens has motion sensors and tiny motors that move the lens elements to compensate for camera motion, producing clearer pictures when hand-holding the camera.
Oct 23, 2010 | Nikon Cameras
On a new Nikon 18-55mm AF-S DX Zoom - Nikkor f/3.5-5.6 lens and a Nikon 55-200 mm AF-S DX Zoom f/4.56 lens is VR also included and standard?
Nikon currently lists two 18-55 AF-S DX and two 55-200 AF-S DX lenses. One in each pair has vibration reduction, the other does not. The ones with VR in the name have it, otherwise it doesn't.
VR isn't exactly an option. If it wasn't built into the lens initially, you can't add it later. A lens either has it or it doesn't, though if a lens has VR it can be switched off.
Aug 30, 2010 | Nikon Cameras
I can't tell the diff between VR and VR OFF with my Nikon 18-200 lens. Is there a foolproof way to tell if VR is functional?
Charles, I can save you the effort. The D200 lacks the menu item I suggested and will not show any symbols in the viewfinder or LCD to indicate which VR setting you have the lens set to.
But Ken Rockwell's guide to the lens has a big clue: VR takes a moment to stabilise, so you ideally need to half press the shutter release and wait a second or so before firing the shutter.
I don't want to plagiarise his excellent article, so instead suggest that you click here to read what the man has to say himself. He discusses the benefits of your lenses VR early in the article, but you may want to skip right down the page to the heading, "How to use the VR".
Ken has also created an excellent alternative D200 users' guide, click here.
Good luck, and please take a moment to rate my reply.
P.S. If the hotlinks don't work then the 18-200 lens review is at:-
http://www.kenrockwell.com/nikon/18200/18200-vr.htm
and the D200 guide is at:-
http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Aug 05, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX VR Zoom Lens Logo
484 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
