Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag model MCE8000AYW seems to struggle with tub turning initially...how do I fix it?
When you push the button to start the dryer...it seems to struggle to turn the drum. how do i fix this?
6ya staff
SOURCE:
Anonymous
SOURCE: Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Posted on Jan 23, 2007
myob247
Georgia B
  • 1342 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Possible causes for your issue include:
Blown fuse
Timer or motor inoperative
Housing wiring not properly connected to dryer
Bad door switch
Faulty "Push to Start" switch
It would probably be best to have a professional pinpoint the exact defect.
Click Here for a very good source of information on Maytag dryers
Posted on Jul 17, 2008
Anonymous
SOURCE: Maytag MDE6000AYQ Dryer
Sounds like the belt that rotates the drum may be slipping. Does your drum turn ok when no clothes are in it? If you have to start it by hand and then it rotates ok chances are you need more belt tension.
Posted on Sep 04, 2009
John Hall
  • 1218 Answers
SOURCE: Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Posted on Jan 07, 2010
Testimonial: "Jack was a great help. Really took the time to help me with my problem in depth. Thanks again."
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Gas Dryer only runs burner once after starting, why
Lets see, you have power to the gas assembly so the fuse is good and the ignitor will fire up. But she won't fire off again. The flame sensor is working because the ignitor is coming on and off. That means the control thermostat is working so everything is working. So what's the problem. Simple.933a1bb.jpg The solenoid coils heat up and quit on these machines with a little age. Very difficult to diagnose unless you know the trick.
Cheap parts link, your part sir: AP3094251,
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 14, 2010
Model mce8000ayw serial 10265874eg maytag Neptune drying center how do I replace dryer belt
Go to www.repairclinic.com and enter mce8000ayw. With luck, you will be presented with a list of common replacement parts and assemblies and may be able to view a generic Maytag video showing disassembly.
Jul 12, 2018 | Maytag Dryers
Changing belt maytag legacy dryer sde515dayw model
Have someone else look at the machine, I'm not sure about the last guy. Do smaller loads to ease up on the machine. It will last a lot longer doing more, but smaller loads.
Nov 29, 2013 | Dryers
Model #MCE8000AYW Maytag Drying Center - The bottom dryer has started making loud noises. It doesn't seem so bad when the dryer has a full load' but as clothes are taken out and the dryer has a...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 30, 2011 | Dryers
I need the diagram that comes with the dryer. Maytag Netune Model MCE8000AYW
depending on the serise which is the first two numbers of the serial number here is the diagram http://lookup.bellparts.com/diagramenlarge/2/0/561302/91934
Hope this helps
Jun 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
All the lights are lighting up but when I hit thew start button i hear a click but nothing happens. Maytag Neptune Model# MCE8000AYW
If there's lint or a problem with the air passing thru and evacuating, the sensor within the system will not turn on the gas or energy to begin drying. Time for a service call.
Oct 08, 2010 | Maytag Dryers
Maytag neptune Model # mdg5500 AWW when i push
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag mce8000ayw start button won't work
your starter button needs checked at least but most likely replacded
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Drying Center MCE8000AYW
Email me a response to robert_fawbush@yahoo.com and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
Please rate this solution "fix-ya" if it seems to satisfy your question.
Apr 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
62 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
