How can I get 6 hs-err-pid13944-Notepas deleted please?
I don't know what i did that made this come up. I am new with my laptop.Each one of the 6 hs-err-pid13944-Notepad that is on my laptop has a different number.
It's possible that you need to format the memory card. Formatting is found in the camera set up menu scroll down to "Format Memory Card" and follow on screen instructions. Formatting should be done after each time you download pictures to your computer. Not delete, as delete does leave some data behind and eventually clogs the memory card so new data can not be placed on it. Another possibility is that the card somehow has become locked I'll include a diagram. Also a new card needs to be formatted to the camera it is going to be used in.
Error 002 says memory card is full. Try to delete the card or reformat the card and observe if camera wont allow to format the card. Try plugging it to a computer or laptop that hs Memory card slot and can read SD/MMC cards and format the card from the laptop
Try resetting your base unit by holding [find hs] button while reconnecting power.
If it doesnt resolve your issue, try pressing the [find hs] button which is said in your manual..This would reset your device and restore you to normal state
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
perhaps it is in "mute mode" which can be activated on the headset itself by simultaneously pressing both the up and down volume buttons.
Also, have you tried deleting the device from the phone you are using before you pair it up again?
finally is there any firmware/software update available for the phone? This can be the case frequently with bluetooth problems with Blackberry devices (I know this from painful experience with this same headset).
Good luck.
