I am trying to install them again but when i had them on the tv i could not see all cameras at the same time which was a big hassel really
You will need a multiplexer to connect all your cameras into and out to laptop on the front of the multiplexer you can use the buttons to see one or all the cameras you have installed.
The ability to simultanously playback multiple cameras is a feature of the DVR. If your DVR only allows you to playback one camera at a time then it most likely is a limitation of your DVR and nothing to do with how you are viewing them (through an app, computer or directly on the DVR).
DVRs that allow simultanous playback of multiple channels have faster decoding chips and cost are usually slightly higher.
I would recommend checking out some DVRs on ebay For example check this one out - http://www.ebay.co.uk/itm/Securenet-4-Channel-Full-960H-D1-CCTV-Digital-Video-Recorder-DVR-with-Hard-Drive-/251642118316
If you look at the specifications on the bottom, under "playback" it says "4CH 960H /4CH D1" which means you can playback 4channels simultaneously at 960H or D1 (resolution).
