I purchased a Sharp blu-ray Aquos bd hp22 secondhand it will play normal dvd's but wont play blu-rays and the remote wont work..help me please.
SOURCE: how to update soft ware on my blu ray dvd sharp aquos bd-hp20
here is the link for Sharp BD players.download and follow intructions that are with the file
http://support.sharp.net.au/drivers/
SOURCE: SHARP BD-HP16U Cannot Play
Try this....
You need to force the player to the the Top Menu of the disc.
The way to do this is: load disc, wait until it says "Reading Completed" (about 1 minute).
Wait for the PLAY icon ">" to show in the upper right corner (this may take up to 30-40 secs).
Once you see the ">" Hit the STOP button on the remote to get to the player's splash screen.
From the Sharp splash screen Hit the "Top Menu/Title List" button on the remote and wait for the circulating dots and then the disc menu appears.
Play the movie from the menu and you should be good to go.
~JC
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
SOURCE: my blu ray player won't play blu ray copy of avatar
Try completing the update.
The update file can be found here http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Select bluray disc players
model not listed
type in model number
Then click on search
Click on the instructions and read thme if you need to. If you do not need to read the instructions click on the firmware and save it to your desktop. After the download has completed open the folder and click on extract all files under folder tasks, which should be on the left of the window nearer to the top.
At this time insert a 1, 2 or 4 GB flash drive into your computer. Then in the window click on next if you need to or browse and then my computer and then the icon of the usb device itself. Click on extract or next. When it is done safely remove the usb device from your computer by clicking on safely remove hardware located near the time on the bottom right hand side of the computer monitor.
Click on the usb device and click on stop. Remove it from the computer and place it in the back of the bluray player. Turn the tv and bluray player on as if you were going to view a bluray. There shouldn't be any discs inside. Press the setup button on the bluray remote control. Choose settings. Choose software update. Begin the update. After it is completed turn off the bluray player before removing the usb device.
If the usb device needs to be reformatted or if the zip file folder is placed on the usb device instead of the extracted file the download will not be successful.
SOURCE: Blue ray won't play Avatar?
There is a firmware update for the BD-HP22. I had the same problem with Avatar but after I installed the firmware update, it loaded and ran smooth. Use the USB flash drive that came with the player or any other usb flash drive to load the firmware update. Check the link below for instructions and update file from Sharp's website.
