SOURCE: how to reboot my toshiba E-Studio 232 black and white copier?
if u want to reboot hard **** just go to 08 mode .then press 690 press start .2 is normall format .shut power off when reboot machine appears .
SOURCE: Toshiba e-Studio 232 is showing error message CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
SOURCE: how to clear time for periodic mintenance display
Go into (08) mode by holding 0 and 8 when turning on the copier. 251 is the number of copies until it displays that message and 252 is the count since last Preventative maintenance. Resetting 252 will clear the message or putting 251 higher than the value of 252 will clear it as well.
SOURCE: unable to access scan folder
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
