Question about Kyocera FS-920 Laser Printer
Ecosys printer missing developer unit
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
Call 239 939 5383 they can try to locate one for you and quote you a price for a new one
Posted on Aug 07, 2014
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 201 Answers
SOURCE: missing developer unit
Generally this printer can be separate into 4 major part: Printer body, Toner container, Developer unit and Drum unit. The developer unit is the unit where the toner container "mount" on it and it should be removed to allow cleaning task every time the toner container is replaced.
U may get this error message if the developer unit is not install properly after u replace a new toner container. Just lift the developer unit together with the toner container out of the printer and then insert back properly into the machine.
YBC (/\)
Posted on Oct 02, 2009
Anonymous
  • 201 Answers
YBC (/\)
Toner on the back of copy
unit dumping toner or developer. usually caused by using non OEM supplies. have unit cleaned and use kyocera supplies
Jan 15, 2016 | Kyocera Ecosys FS-6525MFP Laser...
Waiste toner box full.....how do I clean or change this? Looked through owners manual and can't find anything about it.
The waste toner sensor has detected
that the waste toner reservoir (drum unit)
is full.
FS 1128 has drum and developer as separate unit, waste toner gets collected in the drum unit . Right or left side of the drum unit has a cap fasted with screw, open it and remove the waste toner.Refix the drum and this will solve the probelm
Oct 08, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
FS1128 whats the setup for dev on this?... is it like the CS2550 ? U130
1-5-5 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the front cover.
2. Remove the developing unit.
3. Check or replace the developing unit and
refit all the removed parts.
NOTE:
When the periodic maintenance (replacing
the maintenance kit, see page 2-4-4), perform following maintenance modes.
1. U251 Clearing the maintenance count (see
page 1-3-39)
2. U111 Clearing the drum drive time (see
page 1-3-33)
3. U130 Initial setting for the developing unit
(see page 1-3-34)
Jan 28, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Developer unit not installed
yocera ecosys fs-1124mfp toner container 0r the developer unit is not install
Apr 09, 2012 | Kyocera Office Equipment & Supplies
Brand new on power up attention light continually flashes and message says Please wait (Adding toner) and stays there forever
It is normal to do this "adding toner" operation aprox. 20 minutes. You have to wait until the printer enters in "ready" status. Take a little brake and relax, your printer needs to fill/refill the developer unit with toner dust from the cartridge.
Feb 16, 2011 | Kyocera FS2020D ECOSYS Monochrome Laser ...
HOW DO I CLEAN MY KYOCERA FS-2020 ECOSYS MONOCHROME LASER 35 PPM
Cleaning the Printer
To avoid print quality problems, the interior of the printer must be
cleaned with every toner container replacement.
1 Open the top cover and MP tray.
2 Lift the developer unit together with the toner container out of the
printer.
3 Use a lint free cloth to clean dust and dirt away from the registration
roller (metal).
4 Insert the developer unit together with the toner container, back into
the machine.
5 Close the top cover and MP tray.
6 Open the left cover. Use a lint free cloth to clean dust and dirt away
from the vents.
7 Close the left cover.
8 Use a lint free cloth to clean dust and dirt away from the vent on the
right side of the machine.
I hope this is helpful,
Shawn
Jan 25, 2011 | Kyocera FS2020D ECOSYS Monochrome Laser ...
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
May 07, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Missing developer unit
YBC (/\)
Jun 02, 2009 | Kyocera FS-920 Laser Printer
YBC (/\)
Jun 03, 2008 | Kyocera FS-920 Laser Printer
Kyocera FS-920 Laser Printer Logo
358 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
