48(m+3)-102=6(8m+7) you open the bracket 48*m + 48*3 - 102 = 6*8m + 6*7 you have 48m + 144 - 102 = 48m + 42 collect the like terms together 48m - 48m = 42 - 144 + 102 you have 0 = -102+102 you have 0=0 you have a final answer of 0
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
Euc? Do you mean ecu, the computer? Don't think so. Something in the cluster, maybe the little voltage regulator on the back of the cluster. But if the engine light is flashing, definitely have it scanned for trouble codes, first, to see why the light is on. The light may indicate a poor link or connection with the cluster.
USD50 for the ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Unfortunalty when you get a JVM 102 error JVM Error 102 means There is an issue with one or more of the .cod files installed on the BlackBerry smartphone. During the boot up cycle, the .cod files on the BlackBerry smartphone were checked for modifications and problems were determined to affect one or more files
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
