How can I get a instruction manual to set my Philippe S+arck PH-1087 properly?
SOURCE: philippe starck ph-1071
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps,
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: philippe starck with fossil ph-2006
SOURCE: No Manual. How do I set the time and other functions?
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and you will find a list of generic instructions in which you should be able to find a set that suit your watch.
SOURCE: i need a manual for a philippe starck ph 1065
You can get instructions for your watch from the Fossil web site.
Go to "fossil.com", go to the bottom of the page and you will see a
menu, click on "customer care", and then look under "Product Info" on
the left and you will see "watch instructions"
Click on this and a list of diagrams and watch descriptions will appear. Put
your cursor over any of the descriptions and a diagram of the watch face will
appear. Search the list until yours appears and download.
